This one is very strange. I installed a monobloc, single lever chrome tap about 2 weeks ago. Tested before fitting and everything sound, no leaks. Then installed it into the basin - again, everything fine, no leaks. The strange thing is that, every now and again (say every 2 days or so) it starts to drip from underneath the tap (through the hole in the basin). Then it stops! I've never been able to get there when its actually dripping but clearly quite a bit comes out (as shown by the pool of water underneath!). I can see "wetness" at the base of the tap when I look up through the basin hole, but can't work out from where.
The bathroom isn't used very often (its OK, we do have another!) but I'm totally perplexed.....what on earth can cause a tap to drip/leak from underneath only now and again, that can start when its not being used, then stop by itself?! Aaaargh! Any thoughts would be very welcome
