What I have agreed so far with BC is that my dpc will be one course lower under the bi-folds which will give me a minimum sill inside.
But they also said I need to maintain a 150mm under the bi-fold, which is fine, I have room, but it means I have that size step outside onto future patio most likely.
Could the ground be higher under the bi-folds as any water splash back will only hit the glazing...?
How do other people with bi-folds get away with similar internal and external levels.
And if you go for a sill without one of those sloped drip tray things the water runs down glass and the internal channel also and straight onto dpc, what's to stop the water pooling on that edge and seeping back under the sill into your cavity?
Any thoughts would be great before I ring BC again.
Hank
Hank
