The internal wall at the none tap end of the bath is not at a right-angle to the side wall of the house. This results in a gap of about half an inch between the internal wall and the bath on the wall side of the bath. The gap gets smaller as you move along the internal wall and by the time you get to about 90% of the width of the bath the gap is nonexistent.
A while ago I stated to get water coming down the kitchen wall. As it turned out there was no render on the walls for about the first 8 inches above the bath. There was just plaster which had blown. I scrapped off most of the plaster and then I removed the rest with a wire brush and washed the wall.
As I am going to re-tile the area I just put render on the wall so that it is flush with the plaster.
However, for the internal wall I am going to thicken the coating on the wall at the top of the bath and then tapper it off as I go up the wall. This will get rid of the gap.
The bottom 8 inches is easy because it is just the bare wall and I can render it but what do I do about the area above it that has been plastered.
Can I put a PVA mix on it and render it or do I have to remove the plaster and the apply more render to it or do I have to add more plaster to the wall
Robert
Robert
