i'm needing a wee bit of advice, ........
Before tiling on top of the old grey tiles i know to give it a good wash with sugar soap.
My problem is as you can see from my pics i've tiled the shower cubicle area and worked my way along the top of the bath,where i'm left with cut tiles. How do i tile the tap/basin/wc wall? Where do i start?
My tiles are 40cm long, so i'm assuming if i've got a cut part of tile, of say 10cm, in the internal corner of the wall which runs up the side of the bath, then i'd have 30cm of tile meeting it on the window wall, ie to make up the total of 40cm? Is that the correct way to do it?
Also how do i go about tiling the window wall?
I reckoned on fixing a wooden batton level with the top of the bath,and tiling everything above it.
When set, remove batton and tile from the skirting up,having a 'dry-run' with tile spacers so it all works in?
