Hi
Just stripped the wall paper from the hall and there is rusting on the corner beads. It is not bad and will sand off
They are old steal ones can you advise after sanding what to do to cover them as I am going to emulsion the hall and do not want any future rust staining coming through the paint work.
I was advised to under coat them with an oil based undercoat but then was told the emusion would not stick to that and flake of after time
