I have having trouble with my combi boiler recently. It has been leaking intermittently, pressure all over the place and sometimes water is heated but no central heating.
Was hoping to get it fixed.
Had an engineer look at it. He ran a few checks and then took the front off for inspection .He found the top section of the boiler was significantly corroded inside. He has said that this is very dangerous and the boiler needs to be replaced.
Is corrosion normal within a boiler? Is the engineer correct?
Thanks[/img]
Thanks[/img]
