I am fitting an internal door in an door opening which used to be an outside door before extension was built. The wall is made of brick and concrete block. I have bought a door lining and some 63x38 cls. What type and size of screws do I need to fix the 3x2 to wall one side of opening and the door lining which is 32mm thick to the other side of opening. I'm not sure whether to use frame fixers, brown wall plugs and screws or those screws which drive straight into brick/block. Any help appreciated.
Victor
Victor
