I'm new to these forums but hopefully some friendly people can help me out with a few questions...
I've recently become the proud owner of my first house We have some plans to do a bit of renovation and I decided I would like to try and do as much of the work myself as possible as I think it's all important life skills to learn! So a few weeks after moving into the house, I promptly started ripping the architraves off an internal doorway that I'm planning to block up, as there is another door into the room that we will be using.
I started by building a stud frame and fitting plasterboard to fill the hole, but now I have come up against a few issues / questions and I'm not quite sure how to proceed. Hopefully you guys can help me out:
I would really appreciate anybody who finds the time to read through my post and offer any suggestions.
Cheers!
- When pulling off the architraves, some plaster and underlying render (about 1 inch thick) came off the wall. What's the best way to patch this up? The local DIY store recommended ready-mix cement?
- The plasterboard I've fitted is a couple of centimetres sunken in from the original render. Do I need to re-fit the plasterboard so as to make it flush, or should I put render on top of the plasterboard, or is there a better approach? I can't think how I can make the framing so that the plasterboard is perfectly flush.
- The existing render and plaster has cracked at one of the top corners of the doorway up to the ceiling. There are also a couple of bits of loose render along the sides. Should I pull this off the wall and patch it up with new render and plaster? I'm a little concerned about making it worse and having to re-render the entire wall
- I'm probably going to get a professional plasterer to skim the wall once I'm finished so is there anything I need to bear in mind to make his job easier? Would I be better off getting him to sort out my render problems also?
Cheers!
