internal double check valve outside tap
16 Jul 2009
Hull
If fitting an internal double check valve on an outside tap, is it the not.needed to fit an outside tap with check valve in it
I f you fit an internal double check valve (as water regs require for a new installation) then fit a standard 9no check) extenral bib tap
