Good Morning
House is detatched, basic render & cavity wall (unfilled)
I was looking into insulating the upstairs rooms from the inside, bit of a pain with curved ceilings etc
But i was looking to insulate the 2x external walls and around the window frame this summer in prep for next year
So will need to remove the radiators in prep and refit/move when its done
Am i best going for the 60mm PIR insulation or the foiled back suff then plaster board over it?
I have done the small room last year with the basic insulated plasterboard foamed to the brickwork which helped but want the bigger rooms to have more insulation.
So was looking at 60mm insulation and then plaster board over the top? I was just going to batten the wall and fill it that way to get a good level finish for the plaster board, or would it bet fitting some sort rock wool/fibre glass style insualtion inbetween battens?
Just dont wan to cause an issues with moisture etc, i will have to drop the depth of the insulation around the windows even when i nock the old plaster off due 60mm being too deep.
Ideally in prep for next winter so when i heat the rad's up the rooms will stay warmer for longer & rad thermostat will click off
