I have a single skin concrete construction - I think called shotcrete.
I have removed plasterboard and 13mm polystyrene sheet to reveal a timber framework with felt to the outside of that and then about 80mm of in-situ concrete and render.
I propose to internally insulate with 70mm celotex PIR, foil taped joints between boards, ceiling, floor and internal wall, then Knauf vapourshield plasterboard, then tape & fill. This gets me to 0.28 u-value and deals with vapour barrier issues.
Q - is this correct method for internal insulation?
Q - How is it best to fix celotex and plasterboard? I was going to bond celotex to timber frame and then screwfix p'board through celotex to timber frame (110mm drywall screws)
Any ideas please
Any ideas please
