We are just about to start a refurb on our 1920's detached house. Although we have a small cavity (60mm) we aren't convinced it is sound and therefore are reluctant to get cavity wall insulation due to the increased risk of damp. We are instead leaning more towards internal wall insulation on the external walls. We aren't worried about the loss of internal space that comes with internal insulation.
We will be looking to take the old plaster off and will just be left with bare brick. We thought that the Knauf Thermoshell system looked good but I've just found out they have taken this off the market. http://www.knaufinsulation.co.uk/media/915296/kine1089gid_-_iwi_design_guide.pdf
I wondered if anybody can recommend something along the same lines? I've seen the Insulated Kingspan plaster board but not sure how effective it is.
We also have lots of chimney breasts throughout the house on external walls (every bedroom and in livingroom/ sitting room) and wondered what we do about insulating them? Most of the chimneys won't be used and are capped off but we want to retain them. Do we therefore insulate across the front of the chimney breast or do we leave it. Leaving it seems a bit odd as in my mind defeats the object of insulating the other external wall in the room of we don't bother with the chimney breast wall.
I've also read that you need to avoid thermal bridging by continuing the insulation below floor level and returning it 600mm on the adjoining internal wall. Is this supposed to be at the same thickness (guessing 100mm)? Surely by doing this you are left with a step on the internal wall. The only way to avoid this step would be to carry on the insulation all the way along the internal wall which would obviously mean further loss of internal space and increased phaff around door frames. Is there some magic insulation that you can use on the returning wall that won't result in a step but prevent the thermal bridging?
Thanks in advance.
Thanks in advance.
