Hi all.
I've been lurking for a while, but never posted until now. I'm about to undertake a fairly major DIY project, and I'm wanting to get some expert opinion on a few issues....
The underlying problem that I'm looking to address is a damp problem in an upstairs bedroom. The major damp issue is on one elevation, but also happens to be a wall where there is a full-width, full-height set of wardrobes - which I imagine are blocking airflow to the wall pretty well. The room has 3 external walls.
The house is constructed of red brick, with a cavity, and there is polystyrene-bead cavity insulation. The wall is rendered to the outside, but the render is in very poor condition and needs replacing fairly soon (financial constraints prevent this for now). The house is in an exposed position, and the main dampness inside corresponds with the part of the house that catches all the weather on the outside - prevailing wind and rain are pretty consistent here.
I've read that cavity wall insulation should never have been installed in a house of this type in such an exposed location, as it acts as a 'bridge' for moisture when under high wind load - but I guess there is little that can be done about that for now, I bought it like this!
I am unsure whether the dampness is purely condensation, penetrating damp, or both. (There was active woodworm in this position in the house when we bought it a few years ago, so I'm inclined to think there is definitely some penetrating damp).
The plan in my head is to remove all existing plaster, then build a 50mm metal-framed stud wall internally, immediately adjacent to the brickwork(on all 3 external walls), then in-fill between the studs with 50mm kingspan and clad the whole lot on the room-side with insulated plasterboard (25mm insulation on 12.5mm board). The room is not large, but I'm prepared to lose the internal space as it is my toddler's bedroom, and eliminating the dampness is more important than the space. I will also be removing the ceiling and insulating that while I'm at it.
My main questions are these:
Do I need to leave an air-gap between the stud wall (complete with in-fill insulation) and the brickwork? My current plan leaves no gap to speak of.
Do I need to incorporate an additional vapour barrier somewhere - I guess immediately adjacent to the brickwork?
I'm currently thinking I should incorporate a vapour barrier... is there a reason I shouldn't do so?
Is 'vapour barrier' just a posh way of saying 'big sheet of plastic'? Or are there some overpriced 'breathable' things I should be considering?
I think that covers it for now....! Any input will be gratefully received.
Many thanks in advance.
