Internal Load Bearing walls?
17 Jul 2014
London
All
I'm looking at knocking a wall which was partly housing an immersion heater (attached is house plan)
I'm planning on converting the area to stairs to access our potential loft conversion
My plans are in red-
Add a window to the external wall so it's in the middle of the house to let light in to the hall
Add a new wall in Bedroom 2
bedroom 2 door is moved to the other side
Remove 3 walls from the immersion area as that's now empty, and that area will extend to the new wall
WC the door is moved and turned into a pocket door.
The question I have, is how do I tell if the walls are load bearing? They are quite thin, looking in the loft, I have a massive bit of timber going left/right across the walls (in blue) and very thin joists going back/front.
If you are serious about having the work done then the simplest thing is to get a designer in.
Thin walls are not load bearing. If your door casings upstairs are 4" or less then the walls are extremely unlikely to carry any significant load.
How big are these ceiling binders? Are they both gaining support from the stair well walls?
Nose
Thanks for replying, the two beams are just under 8m in length (single piece) and about 4" thick square. From what I can see, they are only holding up the ceiling joists from below.
I'm in between architects :)
I don't know if it's me, but architects around by us don't have that out of the box thinking. I went to the home renovation show in the NEC over the weekend, and after 15mins with an architect (someone who edits a monthly house magazine) the internals have been designed just make sense and works :LOL:
