Internal pipe stop end
8 Mar 2020
I have a shower head that leaks ever so slightly (2 drops per minute or so), which I never use. I remember there were some plastic stop ends to put inside the pipe before I screw on the shower head (I still want to heave the shower head on, it just won't work), but can't find them online. Does anyone know what I am talking about and how they're called? A link would be much appreciated.
Do you not have an isolator tap fitted to the feeds?
It's not that, it's a 3-way shower system, with rain / tub / shower head. I am using the two, I just don't need to use the rain one which is dripping. Hence I want to cap it from the inside so that there's not just a pipe protruding from the wall.
There will be a small rubber washer where the shower head screws on. Just replace it with a rubber disc with no hole in the middle.
