Internal sand and cement render/undercoat
5 Sep 2007
I have built an internal wall across a room and want to tie it in with the wall on both sides. The original wall has a sand and cement undercoat and I want to do the same with the new wall. No problems plastering it but what ratio of sand cement should I mix for the undercoat (about 1 inch thick).
Any help appreciated
scratch coat is the first coat of render which you scratch up, these scratch marks give a key for when the top float (smooth coat) goes on. You may have seen rendering with lots of lines in it, this is the scratch coat.
