Hi Guys,
Just knocked down an internal partition wall in our bathroom made from 1930 ashblocks that were only 2.5 inch wide (+ render). The main reason the wall came down was because I am having a new boiler installed from tomorrow and after discussions with my plumber, we decided it would be best to replace this wall with a stud wall and place all the plumbing down through the this.
I need to buy the timbers tonight and just want to double check a few things.
1. Should I buy treated or untreated timber for a stud wall frame? It won't be exposed to any wet, but just making sure.
2. As the blocks were only 2.5 inch or 62mm and I want to not loose any bathroom, I assume I need to get timber + 25mm (plaster board both sides) to make the same width wall. That's only likely to allow me to use 60mm timber for the frame. I assume this is okay?
Thanks in advance.
Thanks in advance.
