Hi, I want to put a door (where an old pvc door used to be) between the hallway and porch. The floor is level and the dimensions are something like 2050mm high and 1740 wide.
Im trying to have a central door and 2 side panels.
I want the door to match all the other doors in the house and the side panels too if possible.
The company that make the door make matching archtrave and also matching lining.
(not that i will need archtrave really, as its a corridor)
Thing is - if a frame is made, it wont match the doors. (walnut)
I see vestibule frames, but they all have a bottom bar, and also wont match...
so, can i put lining all the way around (top and sides) fix the 2 side panels well to floor and top and 1 side (a door chopped in half lengthways) then mount the central door to one of the side panels.
Effectively this is hanging one door from another (fixed) door?
Thanks so much for any help
