Hi
Looking to knock through an internal wall. The wall is single brick and extends upstairs but does not support any roof structure.
I am looking to generate a 2m apeture and have been advised by my architect that a 2.4m catnic lintel will be sufficient to take the load.
Can I simply carve out a 2.4m slice of the wall, install my catnic and then work downwards removing the brickwork? Or should I really use a prop and needle approach?
Can I rest the lintel on the existing brickwork or should I a concrete padstone?
Cheers
Cheers
