Hi all
I will be insulating my kitchen walls shortly from the inside (walls are back to plaster) which are solid brick - 2 brick width.
Options look like Celotex whcih are coming in quite competitive to Kingspan for example.
Have seen the TB4000, GA4000 and PL4000 ranges.
Benefits of PL4000 is that the 12.5mm PB is already bonded to the PIR, so I could just have the boards dot and dabbed to the wall.
Howver PL4000 boards are quite pricey.
The TB4000 range is just the insulation, but designed for thermal bridges according to celotex website. However, does anyone know if it can be used for the same applications as GA4000 as the sspec looks very similar?
I was thinking of getting the insulation, bonding it to the wall (guess it would have to be battens), then bonding PB to the insulation, effectively making up a Pl4000 sheet. But as its foilbacked, not sure adhesive would stick well to it.
For example, Pl4000 40mm + 12.5mm PB is coming out at roughly 40 + vat for 8x4, whereas 35mm TB4000 is approx 18+ vat plus say 7/8 for 12.5mm PB.
Anyone used any of the above - if so any feedback would be appreciated.
