I want to insulate the solid brick walls of my house, but I am confused about a few things and need some help.
I intend to use something like celotex GA 3000 (50mm) foil backed boards or the kingspan equivalent. Due to space i would like to apply these directly to the wall with minimal thickness.
What the best product to use to stick it to the brick walls (assuming i remove the old plaster). Drywall adhesive? no nails? something else?
I then want to fix the tapered plasterboard to the insulation. Can i bond it directly to the insulation or due i have to use drywall screws. I have read that you should back up any adhesive fixing with drywall screws.
If i use drywall screws do these have to fix into the insulation or do need to use some fixture into the brick behind the insulation.
I was orginally planning on using insulated plasterboard but these seem expensive in comparison. Am i correct in thinking a GA 3000 bonded to a plasterboard give pretty much the same product?
