I currently have a solid wall (no cavity) double brick house where all the wall are dry lined with 12mm plasterboard which are dabbed onto the bricks. I am thinking of replacing all the external walls with 50mm celotex dual foil backed insulation and fixing/screwing these to the walls after removing the old plasterboard. I will then apply 12mm normal plasterboard on top of this and skim. I remember when i had the walls dry lined, there were visible air bricks above the floor boards. Are these ok to cover over with the insulation? To re-fit the rads I intend to use wooden batons and screw the rad brackets onto this to be more secure. I plan to leave all the internal walls as they are.
I'm after some advice on the above to see if thats ok to do. Also, im going with 50mm insulation as i dont want to go with 40mm only to find that it is too thin.
Thanks in advance.
Thanks in advance.
