First Post(prob first of many)....Hello all
Basically im in the middle of renovating my new home,i have 3 internal walls that i need to build.All walls are non load bearing and id like to do them in concrete block(not fussed on stud walls).I would like to know if there is any problems with this,as the walls would be straight runs.I will use furfix to tie them to the outer skin and if possible i would like to cut out and tie them to the inner walls(or is that over kill?)...any info would be gratefully appreciated...cheers
Gaz
Gaz
