IP POE Cam - advice needed
27 Sep 2011
I'm interested in a riolink ip poe cam..
What i wanted to know is whether these ip poe cameras will work by simply inserting and ethernet cable from my wifi modem into the back of the camera?
Or do i need any additional equipment?
Also, what would be the best /most conventional method to connect the camera, if my camera is attached to the soffit (at loft height) but my modem is wired and on the ground floor?
normally no.
the camera needs power, if your router has POE then it will work if the power the camera needs doesn't exceed the POE being used.
some cameras have the option of a 12VDC connection as well as the ethernet connection
yeah only ever come across one router that was capable of powering a camera and I was surprised.
Thanks guys
Ideally i would like to install my cams on the soffit. For a clean install, I'd have to have the router in my loft area. However, my WiFi modem is on my ground floor.
Is there a way to make this work without running a long ethernet cable from my modem to the poe router?
do you have sockets in loft?
No, i do not have a plug at present.
But i planned on adding one via an fcu in the near future. Guess i will have to prioritise this job :D
Out of curiosity is there another way?
even a wifi camera needs power.
so the question is how are you So you could plug it in to a socket in the bedrooto power the camera.
easiest way for a POE camera, is plug it into a POE switch/ injector.
https://www.amazon.co.uk/Richer-R-Injector-Ethernet-Adapter-Wireless/dp/B07F12H9GF/
this link is a single unit, one cable to the router, other cable to the camera.
Now it has to be plugged in so it can be powered, the cables can be run to it.
You can shorten the cable run by getting it close to the camera, but you still need to plug it in, you could use ethernet over mains to get the signal from one part of the home to the other without running cables (uses mains cables), but you still need to plug it in.
so you could plug it into a socket in the bedroom run the cable outside and fix to the camera?
