iphone cctv?
22 Apr 2009
Aberdeen
Hi all I have a cctv system, they are ip cameras, and they are linked into my NVR and then connected into my network and PC.
Now do I need a static IP address for my router and then set up a channel in my firewall to allow my iphone to connect through and look at my cctv?
if anyone has ANY clue how this works, please PLEASE, tell me
I found one very interesting cctv quotation website but it's actually not helping me with my iphone,
Can anybody else suggest any links to any place that knows how to do it?
If you are going to do things remotely then yes, you will need a static IP address.
No, you do not need a static IP address.
You need a service like dyndns or no-ip. Your ISP will most likely not give you a static address.
Plenty of ISP's will give static IP's.
The average consumer ISP will not let you have a static IP, and those that do generally charge for it. Static IPs are generally unneeded, and most people wouldn't be able to remember them anyway.
You do not need a static IP. What u need to do is look into your boardfband router.
in your router setup, if its a consumer router (common brand like netgear linksys dlink etc) it probably have an option to set up a dynamic route.
i.e. if it gives option to enter Dyn-DNS.org user name and password etc, go to that website and register a free single address account. arm with that user name and password, u can get to your router using an alias (given by dyn Dns in this case, probably something like yourname.is-a-server.org).
step 2, u need to route the port matching the NVR internal IP. this is essentially the critical step to "get through". the actual name of the option vary greatly between brands.
step 3, u can now view the image through the iphone browser (I am assuming its a browser based player? if its a custom written app, it can get complex without static IP). your next problem with browser based viewer is plug-in, can it be play back on iphone?
