hi. getting high readings from P-E (>1000) but P-N and E-N both are reading around 0.18 meg ohms. testing by clipping on neutral and earth bars in CU. Am i doing something wrong?
Possibly, the E-N one is a bit odd though. The P-N would make me think there is a neon or similar in the circuit somewhere. If you break the board down can you narrow it to one circuit?
hi
had similar today, it was a plugged in trailing "surge divertor" multi socket thingy that was doing it...
unplugged it and got 4M ohms to earth.
could it be this?
