Renovating my kids’ flat, with several structural changes that will mean changes to radiators positions plus additional towel rails. The very old system pipes are basically scrap and I would like to put in 10mm plastic pipes that could be hidden, running these from a central manifold, 22mm inlet, thereby all joints would be above floor level.
Having utilised 4 radiator calculator sites (why do they differ so much} the figures are as below. I propose to use in the four main rooms exactly the same radiator of 3700 BTU’s, with TRV’s and a thermostat programmer in the Reception (as it is the biggest room with the highest temperature needed, the others would turn off first?). The distances from the manifold to radiators is shown, can I use 10mm plastic to supply the radiators
Sorry I have spent over an hour to produce a table here but it wont take it forward. So shown next to each room are;
Average BTU ; Highest BTU; Distance in metres from Manifold to Radiator
Kitchen 2166 3272 5.5
Reception 2836 3555 6.5
Bedroom Front 2765 3153 4.5
Bedroom Back 2699 3016 6.0
Bathroom (2) 656 792 1.5
Hallway 390 427 3.5
Total BTU 12267 15007
Total Watts 3593 4398
Whilst the distance to the hallway is shown as 3.5 metres this is from kitchen radiator, could I ignore the manifold in this case as the hallway radiator will be only 1.6 metres from the 22mm flow and return pipes, could I tee off these?
Hallway 390 427 3.5
