Hi
I've got some upcoming plumbing work and everything is being drained down for it, so I'm taking the opportunity to replace the boards under the tank in the loft because they have signs of woodworm... I'm hoping to use 18mm ply because it is available at B&Q where they will cut it to size for free, which will save time, hassle, and will mean I can fit it in the car! But is 18mm thick enough?
Here's some relevant info:
- The existing base is T&G floorboards and they're 20mm
- The tank spans three joists
- The joists are 150mm x 37mm. Joist centres are average 400mm apart.
- There are no walls beneath the tank. The nearest wall is a solid internal wall, which is 500mm away from the tank, to the side.
- The tank is 40 gallon / 182L actual (60 / 273 nominal)
If 18mm will be enough, it seems B&Q offer two types of ply and I wondered which is best please?
https://www.diy.com/departments/hardwood-plywood-board-l-2-44m-w-1-22m-t-18mm/5059340257433_BQ.prd
https://www.diy.com/departments/natural-softwood-plywood-board-l-2-44m-w-1-22m-t-18mm/945875_BQ.prd
Many thanks for sticking with me through this bathroom refit and all it involves!!!
PS - if this is more suited to a different sub forum please move it to where ever is best. Cheers.
