is 25mm pipe insulation worth it on 22/28mm pipes
3 Oct 2006
Hampshire
I have a longish primary run (10m flow + 10m return) in my loft in 28mm copper pipe.. I originally planned to lag with 25mm pipe insulation and have clipped it so that I can, however it's pretty expensive (1.75+Vat/m vs 1.10 + Vat/m) .. but so is gas :(
(at the end of the run the primary splits between two UFH manifolds and a vented hot water cylinder)
I was wondering if I will get any significant benefit from the extra 6mm of insulation? I know with loft insulation you get a diminishing return for additional thickness and that the larger the pipe the lower the rate of heat loss/vol (I think?)
I have the same question for the same length pipe run for a 22mm copper hot water loop, which for obvious reasons I want to loose as little heat as practicable
any thoughts?
cheers
Trevor
Heat loss in the loft is totally wasted so thick insulation is advisable.
Heat lost within the house has a useful heating effect for 8 months of the year so does not matter so much.
Tony
it's all in the loft so.. thick as in 25mm? or as in 19mm? (9mm is the thin stuff isn't it?)
I guess it's just one of those things, you get what you pay for.. I am just curious really.. all told the 25mm will cost me an extra £80 (180 instead of 100) I'm curious in a very handwavey kind of way whether I'm likely to make that back in gas savings in 1/10/100 years :)
thanks! was hoping I could get away with 19mm given the price differential..
I'm guessing I'd be looking at closer to the 10 years than 1 to make the extra investment back..
a cheaper option would be to lag it with the small studd then get some 100mm fibreglass insulation and wrap that over the pipe, will be way cheaper.
not a bad idea.. I have some 100mm insulation, might look into how easy that would be to do.. :)
cheers
Trev
