Is a batten needed at doorway under floating floor?
mno
15 Jan 2008
Part converting garage to 2.4m x 2.4m utility. Have levelled concrete floor, 1200dpm, fitted 100mm then 50mm (90 degrees) solid insulation. Vapour barrier then tongue and groove 18mm MR chipboard, glued. Was quite pleased. Have recently read on some insulation websites that there should be treated softwood battens at the doorways. Have a doorway from kitchen - nearly level and a back door where you step down to go outside (approx two bricks). Will the battens be needed and if so, where ? Any advice welcomed.
Would fitting a second layer of 18mm chipboard help ?
