My parents let out a flat built in the mid 60s. The main stop valve looks like it has been attacked by previous owners armed with Stillsons over the years and only just shuts off if you use a lot of force. It's not leaking around the spindle (yet).
Could I install a full-bore, lever ball valve downstream of the old valve, and just leave the old valve fully open and semi-seized? Not ideal, I know, but less risky than messing around with freeze kits. The valve in the road isolates the whole block, and looks a nightmare to turn anyway.
Was thinking of Screwfix 80413 which claims to be WRAS approved: http://www.screwfix.com/p/full-bore-lever-ball-valve-15mm/80413
Pipe is copper, presumably 1/2", so I'd have to use appropriate olives.
Thanks.
Thanks.
