Hi there,
Have just had a Period Inspection and PATs done to a house I rent out.
Have been advised by the guy doing the inspection that it is no longer permitted to have a non-RCD Freezer circuit and I should change to an RCBO, but he seemed unsure.
The freezer socket is clearly labelled (with Dymo) FOR FRIDGE OR FREEZER ONLY and the tenants are aware of its proper use. The cable is run in surface conduit, (so the circuit itself does not need an RCD as far as I understand the regs). There is no way that socket would be used for anything else - the kitchen has more than enough normal sockets.
In the meantime, I got the sparkie to PAT the fridge/freezer (even though it belongs to the tenants) and it passed with flying colours.
Now waiting to hear back from the electrical firm with the full outcome and am wondering whether this is leading me up the garden path as far as extra work is concerned.
Also, money aside, I thought the whole point of having a freezer circuit was, in part, to have it unprotected.
Please could you help me with your knowledge of the rules, and on the 'need' for an unprotected socket?
Thank you!
Thank you!
