is a redring 7.2kw shower a good replacement for old type
11 Feb 2009
Yorkshire
Hi, Newby needs help please.
Mother wants me to replace her old redring electric shower(not quite sure of model number but it does look an old un) (which now dosen`t work) for another redring shower, thinking of installing the redring active 320s 7.2kw, but unsure about the wiring, this is where i need help, the cable seems to be 6mm (ive measured the outer sheathing and its 13.5mm x 7mm, and the total length of cable is about 10mtr long, i really dont fancy changing all the cabling because its gonna be a pain in the butt.
Any help on this matter would be greatly appreciated ;)
If 6mm i would only replace with 7.2kw, if you start getting the newer 10.5kw then it would require cable changing.
She should also ensure an RCD is fitted
Thank you, Can i easily replace a MCB with an RCD with just a simple purchace from B&Q for instance and swapping them over.
Thanx again for assistance :LOL: :LOL:
