is a worcester 42 cdi combi boiler the right option for me
14 Jan 2008
I'm getting a new boiler. I currently have a cylinder & tank set up, but I want to have a combi boiler for instant hot water.
I have a 4 floor victorian terrace, with 1 bathroom & one shower room (maybe an en suite going in but not for a couple of years). It's not a massive house, only two rooms on each floor, it's this and tall.
Also I'm converting my basement into a one bed flat (that's where the shower room is)
I've been told by one plumber that it's fine to use a worcester 42 cdi combi boiler, he's quoted about £3.5k for the job. A different plumber said that a combi boiler won't be up to the job and I need to have a cylinder/tanks set up again.
I'm confused, any advice, tip etc much appreciated.
A powerful combi like that is certainly going to give you the best chance at supplying a couple of hot water outlets at once with a good flow, but the problem is that you won't know just how well until it's in !
If you're planning another bathroom at some stage, then it would make sense to factor this in now - will all three have showers using hot water supplied by the combi ? That's probably pushing it, so you'd have to be sure they weren't all going to be used at once.
You'll also need to make sure your gas supply and mains water pressure are up to it, so make sure these are checked out before you proceed - your plumber will presumably take these into account.
There are some combi FAQs in the sticky above which should give you some more info.
Theres plenty of combi boilers out there that will do the job, I think the main point here is the mains water pressure, check to see what bar is pushing out the mains then decide.
