Looks like the plaster in my house is a sand cement mix (early 1950's bungalow).. There are a few spots all over the place where when tapped it sounds hollow.. I have been told I need to knock these areas out and fill them in.. Also the electrics and heating is being replaced so there are wall chases in each room that need to be filled..
If the plaster is a sand cement mix can I use browning or bonding plaster to fill up the areas where it's blown? or will it need to be a sand cement mix to be compatible with what is there already?
After its all been filled I plan to get a professional in to do the finishing skim and get it completely flat..
