is dry grouting possible??
30 Jan 2007
Clwyd
Hello everyone.
Ok, i have finally laid all my slate natural stone tiles (25mm thick) down and it is time for grouting. The thought of grouting with a wet mix in the normal way really doesn't appeal to me at the moment. Can I prepare a semi dry or dry mix of sand and cement with a flexible additive. This then be brush over the tiles into all the joints and then finished off with a spray of water to set it and use a grout finisher to finish it.
Help please.
get a shed load of masking tape (self explanatory), a spatula for inch by inch grouting...and knee pads
cuttertree said:
Hello everyone.
Help please.
I wouldn't. Why don't you just grout like normal people do - it's not difficult.
the area of floor to be grouted is quite large, no actually bloody large. Just wondered if there was an alternative method that would be nice and quick.
For heavily riven natural stone I tend to use more of a pointing method rather than spreading with a grout float.
Mix up the grout as normal then use a bucket trowel of pointing trowel to fill the gaps working the grout well in with the edge of the trowel, then strike off level. Does not take too long with wide joint grout.
And make sure you seal the slate before grouting.
Jason
