I am having difficulty getting an answer to this question (from Grundfos) and thought maybe someone already knew. They keep answering different questions.
The pump is a Grundfos UPM 3. It has 3 internal modes (constant flow, constant pressure and proportions, pressure) and one external (PWM)
There is a connector they sell called a mini superseal. It only has 3 wires.
1) INPUT PWM
2) GROUND
3) OUTPUT
You may note that although the pump has a pressure sensor this data is not made available. Hence I am thinking of using ONLY THE OUTPUT with the pump in constant pressure mode. This would allow me to monitor usage and alarms (ESP32 based controller).
My question is simply “in constant pressure mode is the OUTPUT active?” The manual does not answer this question as it assumes simultaneous use of both INPUT & OUTPUT.
I do have an alternative exit strategy if it doesn’t, which involves fitting my own pressure sensors before and after the pump (which is stupid as the pump already has sensors) but will post that in the projects category if that project becomes real.
1) INPUT PWM
2) GROUND
3) OUTPUT
