Long story short, tore down old walls in loft room, and will insulate between studs with rockwool. Would like to avoid cold bridging through studs but don't want to lose room space and mess about with the door jamb if possible. As I have acess behind the studs I could either throw up 100mm glass wool or another round of rockwool slabs behind the studs as well.
This won't cause any issues doing it back to front, will it? Also, best way to hold the insulation against the studs so it doesn't fall down?
