Just a post to see if I am on my own with this.
Recently have completed the instalation of a consumer unit that as the main incommer cables 16mm, and also one circuit going out is 16mm swa,
Now I am meticulous in checking that terminals have been tightened.
I actually Say NEL out loud as i think i am done meaning "Never ever Loose"
which basically is me doing a check sequence of giving the terminals a final tweak (not over doing it either), I do Neutral first, "never" Then the earths "Ever" and then Live "loose"...for me its a good way to do a final check...However. On terminals that are holding multi strand conductor 6-10-16mm there seems to be something at work in that they seem to work loose on their own.
Last night i had a heavy load going through my consumer unit and could hear a buzzing, invetigated and seemed to be able to give every terminal carrying a muti strand conductor a full turn to tweak up tight..
Is it me!!
Is it me!!
