I have a one bed house and basically want to create a very small room in my loft as an office. I dont want to do an official loft conversion and just want to know if its possible to cut two of the binders out ( from outside wall missing the first one 'flush with the wall' then removing the next two) and insert vertical timbers to replace them this would open up a small corner space. my house is divided into two houses each one bed so from the centre apex (if thats what you call it - the top pitch of the main roof) is a concreate block wall dividing the 'house' into two one up one down with bathroom/toilet. I am guessing that due to the concrete block wall providing extra support for the roof and only indending to remove two of the binders and install two vertical supports where the binder would have started (going from the outside of the building inwards - towards the concrete block wall - centre of the actual building) this might be possible? I am not a builder but am not affraid to pick up a book and learn how to do things. Could any 'builders / roofers advise if this is at all possible in theory? Like I say it would on paper simply be a storage place thats plaster boarded and insulated with loft boards already laid. Any productive thoughts on this would be very well received and appreciated. I can provide photos if required. Thanks in advance. heres a good example of the timbers in my roof
http://www.buildsrilanka.com/Images1/Roof_3.gif
I have been looking at the practical concepts of how to reinforce where I would potentially remove the binders from this site. Again just dont want to do anything without checking. Cant risk a sag in a years time and the entire roof needing to be rebuilt. http://www.internode.co.uk/loft/superstructure.htm
