- Joined
- 23 Oct 2020
- Messages
- 38
- Reaction score
- 0
- Country
I'm replacing radiators and plumbing throughout the house in anticipation of installation of an air source heat pump next week. There are two rooms which have double radiators, and especially because I'm using (expensive) smart WiFi enabled TRV valves, I'm wondering if it's possible to connect the two radiators to make them essentially function as a single unit?
As I see it there are essentially three configurations:
(1) Run totally separate 15mm feeds from my 22mm feed/return loops to each of the two radiators with separate TRVs on each (not preferred for reasons above)
(2) Run a single 15mm feed from the 22mm heating feed/return loops and tee off the second radiator off this 15mm feed or...
(3) Somehow connect the two radiators directly to one another. But I fear that this would functionally mean that the second radiator would be running off the return feed from the first. Is there a way to run rads in parallel that will avoid this problem?
