I have a problem with the plastic gutters at my terraced house. When it is raining, the water is dripping from where my gutters are joined with my neighbours' sections.
I called a contractor today to do the visual check before starting the job and that's whaty he said:
1. Apparently, the guys who installed the gutters put them too low, so the water is not moving properly towards the exit (vertical pipes are located at my neighbours' sections- quite far away from my gutters).
2. As my neighbours' have metal gutters, they were not joined correctly with my pastic ones. It seems that only some silicone was used.
The contractor proposed to lift up my gutters a little bit, so the water would flow away easier and said that in order to properly join the plastic and metal gutters, he would need to use some special joints (expensive). All the work would last around 3 hours. And the cost would be no more than 300 pounds.
So, my question is: is it really so expensive?
Thanks,
bhill
Thanks,
bhill
