Could I trouble anybody to answer 2 questions for me:
I have just replaced a celing rose fitting with a rail of 4 spotlights.
1.Due to the fact that the wires left from the ceiling are very short and I can't fix them into the new connector inside the new spots because it is in a box like cover which fits flush with the ceiling. is safe to unscrew the flex connector which is attached inside a box/cover on the spotlight rail, attach the wiring correctly, then just leave the flex connector loose inside the box/cover?
2.The rail is 4 x 40watt and says it's dimmerable, can anyone recommend which dimmerswitch I should get (only needs to be white)
