This has electrical bias, but more generalised I think so posted here.
Is it safe for a diyer to be using a battery powered drill, making holes in walls ... with the mains electricity supply switched off ?
'Frinstance, MP's daughter was sadly electrocuted in recent history .. I did think,just supposition here that drilling thro cable was root cause of tragedy, surely the 'driller' knew he had hit a cable ?
Quite possibly not, with main electric off and a battery powered drill !!
So, what if electrics have already been very properly checked and passed ok, prior to drilling and fixing potentially live kitchen equipment ?
Begs the question .. should we amateurs drill with battery drill ? ... If electric is on and cable hit just on the live... the drill aint earthed !!
If electric off, then one would not without further checks know if cable has been hit.
Is there a case for drilling holes with mains drill... and circuits switched on.
I humbly submit the much maligned screwdriver tester ... proven prior to and after use, on a known live ... COULD be very useful on screwheads in walls and floor fixings, for those drillers without a multimeter !!
P
P
