My workshop has a radial socket circuit fed from a hager 16a b type MCB. I heat the space with a 3kw fan heater. I normally turn the heater off before using any power tools to avoid overloading the circuit. However today I was cutting some wood with a circular saw with a vacuum cleaner and forgot to turn the heater off. I had all three devices running at once for about a minuite with a total load of about 6200w which works out to be about 27 amps at 230v, way over the 16a rating of the breaker. To my supprise the breaker did not trip, should it have done so in that situation? Is this normal or is the breaker defective? If it is indeed normal, do I need to continue turning the heater off before using high power tools?
