Hi, i have been reading around to try and find some things to check for before i call someone. Tried a few things but no luck.
We have a Greenstar 12i system which appears to be dead apart from having the mains indicator light on. It is controlled by a digistat+ rf thermostat which appears ok as it responds to changes in temperature settings. ie, if i turn the thermostat up the green 'heating on' light turns on, and goes off when turned down. No matter what i try, CH on HW off, Both on, HW on CH off, the boiler just does not fire. Makes no noise at all. When turning the boiler off and then on the lights on the front light up for a second and all go off apart from the mains indicator.
I know it's hard to diagnose these things without seeing first hand but are there any basic things i should be looking for before i call someone in?
