I've looked in the wiki and searched other posts but cannot find an answer. I'm not a heating engineer, but like to think I'm fairly logical and can work things out when/if I understand how things work.
Basically I'm wondering if it is a likely failure mode for an automatic bypass to fail so it is permanently open?
Background - my Worcester Bosch CD40 (modulated?) boiler recently started tripping with a E9 Overtemp fault. After following the fault finding steps in the manual (no use) I "fixed" the problem by turning down the power knob slightly.
But the heating does not seem as effective as it used to be - and I don't think it is the power reduction, because that was quite a small change.
What I have noticed is that the bypass circuit next to the boiler seems to be flowing all the time - even when the house is cold and not all radiators are warm with TRV's open. It has a vernier-type scale on it. I've tried fully closing it (clockwise) but the bypass still seems to flow.
Is it possible for this sort of valve to fail open do you think?
Any other ideas?
Any other ideas?
