Hello,
Great site, lots of information, hopefully someone will be able to help me.
I have a 1 bed top floor flat with gravity fed water system, hot water cylinder in the airing cupboard. I currently have adequate water pressure with a flow rate of 5.2 litres/minute.
I have a 166 litre cylinder (at least from my basic measurements) and wanted to know if this was a sufficient size to support a 1.5 bar pump to give better pressure for showering?
My partner and I have a ten minute shower each in the mornings and so currently that would use 104 litres of hot water. or 2/3 of the tank.
The figures I am seeing online for a 1.5 bar pump are a flow rate of 10-15 litres per minute. At an average of 12.5 l/m that only gives 13 minutes showering time from a full tank so not enough for our usage.
Is my maths right? Or do you think the 166 litres tank will suffice?
Cheers,
Will
Cheers,
Will
