Hello all.
I live in a low-rise block of flats, each flat has it's own metered supply. It's known that water pressure is not great in general, and especially in the upper floors (I am on the 2nd/3rd (top) floors). I have checked another flat on the top floor and theirs appears around the same as mine (so I don't think this is an internal pipework issue).
At the top (3rd) floor of my flat the toilet cistern takes a long time (>5 mins) to fill, and the electric shower will refuse to run at peak times occasionally.
Thames Water have measured ~1.7 bar at ground floor, and although didn't provide me a numerical flow rate the engineer suggested it was more than 20 - 25 L/m.
A plumber has measured 5-6 L/m and ~0.7bar static at my kitchen tap (2nd floor), and I have measured 3-4 L/m on the shower at 3rd floor.
There is not enough pressure for an accumulator (or space, or £££), so I was wondering if a Salamander Homeboost/ST Mainsboost type solution might be suitable?
As an aside, it strikes me as slightly crazy that TW are only obliged to provide 1.0 bar at the entrance to the building at ground floor. If that were the case, it literally wouldn't reach my CWS upstairs!
Chris
Chris
