Hi. I'm installing some metal light switches. One box is plastic and doesn't have it's earth connected so I double checked that it's other end was connected . It wasn't so I've connected it into my lighting circuit in the roof. Sounds fine eh.
But.. if I use an multitester to check the resistance between this earth at the switch and the face of another upstairs lightswitch OR the cold water pipe in the bathroom, both give a fluctuating reading of around 1500k ohms. I did this other lightswtich the other day at it and a neighbour already had earthed connected in their boxes. Resistance between them was zero. So is my other box earthed? Multimeter gives a 1 if no connection at all, i.e. infinite. but such a high resistance just seems mad!
They're connected somehow, but could be via a big edam or something. Any ideas? Could I connect the earth to the neutral to check all is working? Where to turn???? HELP !
